Bluesound Node 2, output digital coaxial off. (does not send signal to external DAC)
10 comments
    Avatar
    Wesley P.
    Hello Carlos,
    I'm sorry to hear you are experiencing issues with your Node 2's coaxial output. I have escalated this to our support crew to investigate further for you and help work towards a resolution.
    A member of our support crew will be reaching out to you shortly to gather some further details and help to resolve this issue for you.
    Wesley P.
    Comment actions Permalink
  • Avatar
    Carlos Nascimento
    Thanks for the return, await your contact and solution!
    Thank you
  • Avatar
    Mike Brown
    Hello, is the response in the knowledge base? I am having a similar problem where the coax seems to work intermittently. thank you, Mike
  • Hi Mike
    What you are hearing (or not hearing) is hardware-related. If disconnecting and reconnecting the cable does not resolve the issue, please select Help, Send Support Request in the App for a closer look from our Support Crew
  • Avatar
    VITALIY STEPANENKO
    I have same problem.
  • Avatar
    Hello Vitality,
    Please physically disconnect the cable from both the Bluesound player and the source, reboot the Bluesound player, and then reconnect both, and check to see if this resolves the issue. If not, please select Help > Send Support Request in the App for a closer look from our Support Crew
  • Avatar
    VITALIY STEPANENKO
    Hello, Sam!
    It did not help.
    Sent Support Request.
    I am waiting for your help.
    Thanks.
    Vitaliy
  • Avatar
    VITALIY STEPANENKO
    The optical output works well.
    Coaxial cable and DAC my Parasound HINT 6 works .
    Сhecked on a CD player
  • Avatar
    VITALIY STEPANENKO
    Hello!
    I am still waiting for your help.
    Thanks!
  • Avatar
    Hello Vitality,
    There may be some delay in the support crew responding, as they are working through the increased requests now that customers are spending more time at home due to CV19.
    We thank you for your continued patience.
Post is closed for comments.
