Volume control with soundbar and stereo
AnsweredMy setup:
Pulse soundbar 2i ( connected with arc hdmi on a LG OLED55B6V
Pulse sub
2 Puls flex 2i ( set as stereo)
I combine all the speakers in one group soundbar + Stereo.
When i use my Android app for volume control everything works perfect but when i'm using my television remote controle only the soundbar volume works the 2 flex 2i speaker are not responding to the volume control.
How can i fix this so that i can controle the soundbar and the 2 flex speakers together.
( Dolby is no option for now because there is no possibility to make some different groups see post https://support1.bluesound.com/hc/en-us/community/posts/360021800013-Create-multiple-groups-with-same-speakers )
Hi Edwin
When using the IR you can only control the volume of the Primary player if you are not in a fixed group situation.
If you wish to control the volume of the FLEXes you will have to make a Home Theatre Group. You do realise when you group the Stereo Paired FLEXes with the SOUNDBAR, you are simply rebroadcasting the L and R front channels to the FLEXes and not creating a true surround experience as intended by the film.
Consider selecting WIDER MODE in the Audio Settings of the SOUNDBAR for a better experience...
Yes I realize that we have no surround sound, but I'm not the only one in the house I can't expect that everyone group and ungroup the whole day the speakers if they want to watch a movie in surround or listening to music with all speakers in stereo.
So we decide to make 1 group with 2 speakers in stereo and combined is to 1 set with the soundbar.
What about the volume I have a workaround, ungrouped the 2 FLEXes and learn my IR volume code on each FLEX, grouped again as stereo combined with the soundbar. This temporary solution works for me as expected!
I hope we can expect soon an option to create multiple groups with the same speakers that makes the use a lot easier.
WOW! Great Tip... I will pass that idea along to our Support Crew Bullpen as a workaround.
Thanks for #LivingHiFi
I believe this is fixed in firmware 3.6.3 is that correct?
Yes, the initial volume control issue has been resolved. Thanks Edwin
I still have this issue.. when i set volume higher or lower... only the soundbar changes volumes.. not the both flexes.... software is up to date...
thnx for your help
Hello Allaert,
If you are still experiencing this issue, please contact our support team directly so we may investigate this further for you. You can send a support request through the BluOS app by going to Help > Send Support Request and a member of our support crew will look into this for you as soon as possible.Regards,
Wesley P.0 -
I thought it was fixed but I have still the same issue like before. Please make a fix for this annoying volume issue.
Allaert Hartjes did you still get this problem?
9 comments
