    Thank you for contacting the BluOS Support Crew
    We are currently investigating an issue with a TuneIn Radio outage affecting parts of Europe.
    We ask you select Help, Diagnostics, Reboot to re-establish a new connection with TuneIn Servers in your region. e have seen this resolve the issue in a number of cases.
    Please follow this Community Post Thread for comments and updates; https://support1.bluesound.com/hc/en-us/community/posts/360033958534
    Thank you for your patience and for #LivingHiFi
    Comment actions Permalink
  • Avatar
    Ole H. Sørensen
    There are similar problems with TuneIn in Denmark.
    Do note that this problem is only on Bluesound- Tunein work fine on your PC
    To Bluesound: Are you looking into this problem ?
Post is closed for comments.
