Digital volume control using coaxial output
4 comments
    Yes.
  • Kritoffer Löf
    Hi,
    I have noticed a problem with the new Node (N130) while using the coaxial output to Genelecs. The digital signal works occasionally well but many times it loses the connection and the sound "jumps" between the left and right speaker. I have tried this with several different Nodes and Genelec speakers. I have connected the coaxial through a 75->110 ohm AES/EBU-converter to the speakers. This was never an issue with the older versions of the Node (2 and 2i).
    Is this a known issue and might this be a software or hardware related?
  • Dilip Chawla
    Connecting thru coaxial means you are using external DAC. You need to go to settings-Audio and disable MQA external DAC. This should solve your issue.
  • Kritoffer Löf
    The MQA external DAC option is greyed out and disabled because the output level is in variable mode. The problem looks to appear while using the HDMI ARC-input.
