Complete failure of system
    Wesley P.
    Hello David,
    I can see that you currently have a support request open with our support crew regarding these exact issues. I would suggest to continue working with Jon to investigate this issue further and find a resolution for you as soon as possible..
    Wesley P.
  • David R Willis
    I have now taken all my three players back to factory settings. It was the only solution that I could see working. After many Hub reboots and attempts at connection I grasped the nettle of a factory reset. As I type the system has stopped and is searching for players. Yep.
