Powernode 2i sound control (vocal range)
5 comments
    HI Davor
    Thanks for the feedback. TONE CONTROLS ON is the same curve but a 6 db drop to allow for more headroom when adjusting.
    Comment actions Permalink
  • Avatar
    Davor Mckinley
    Thank you for your reply Tony. I somehow managed to omit the most important detail- the sound difference occurs when playing via built in Spotify or USB port. Anything coming via optical input is fine and the sonic character is preserved. Thanks Davor
  • Spotify is OGG so it just may be the way it is sent. The USB stuff is your content so I can't speak t that. We do not decode any differently based on source ports. 1s are 1s and 0s are 0s to us - try playing with the Replay Gain options... we generally have not had complaints or concerns and are pretty happy with the performance.
  • Avatar
    Davor Mckinley
    Thank you for all your replies Tony. The bottom line is that this little amp is an absolutely fantastic piece of kit and punches way above its weight! I look forward to discovering how to get the best out of it over time!
  • Awh schucks
