Problems with tuneIn
AnsweredHi there, I have problems with all radio stations at TuneIn with my new flex2i: they work for a while correctly but from one moment to the other they stop for a couple of seconds. I only got this problem with TuneIn. If I listen to radio stations via Apple Airplay directly from my Iphone it works perfect. Listening to Deezer works also perfectly without stops.
The flex is connected through WLAN. I have done several resets and also a firmware update at the router and nothing helps. I need the TuneIn radio station to get the radio station on a preset button at the pulse flex.
Hi Dirk
It could be the streams themselves that are affecting it. In the App, on the now playing screen of your TuneIn Stream, select the context menu and try a different stream of that same station.
Comment actions
