How to disconnect a USB-connected harddisk from a Node 2?
4 comments
    Hi Jurgen
    You may simply just pull out the USB drive, no need to disconnect. After a minute or so the USB device will disappear. You can try closing and re-opening the Navigation Drawer to refresh it as well.
    Comment actions Permalink
  • Avatar
    Jurgen Nulens
    Dear Tony,
    Did you actually read what i wrote?
    1) After unplugging i have to reboot everything
    2) USB source stays in the navigation drawer, it does not go away
  • Avatar
    Jurgen Nulens
    Here's a picture where you see the two USB-sources, only the one on top is accessible, while the other has been removed but still visible in the navigation drawer.
  • Hi Jurgen
    This is not normal behaviour from our experience... please select Help, Send Support Request so we may review the system log file...
    I suspect you do not have to restart the Player, just kill and re-launch the app...
