Vault 2 : From NAS Copied Audio data not visible
AnsweredThe music which was copied from a NAS to the Vault2 is visible on the VAULT-folder but the albums are not visible on the "Mediathek"-level like the albums which are ripped with the Vault.
Hi Wolfram
The music must be in the root folder \Music on the VAULT. Once you have done that, please select Settings, Music Library, Reindex to update the BluOS SQL Database.
If problems persist, Help, Send Support Request so we may see the log file.
Comment actions
