Pulse sub making a popping sound
5 comments
    Hi Hermann
    I am escalating this issue so we can take a closer look. We will be in touch.
    Comment actions Permalink
  • Avatar
    Hermann Titov
    Any updates on my inquiry?
    Thanks
  • Avatar
    Hermann Titov
    Thanks
  • Hi Hermann
    You should have received a link referencing your request. Please follow up using that link.
  • Avatar
    Hermann Titov
    I did get a link, but it does not have a solution or recommended path to resolution.  I also got a bunch of links to some docs none of which apply  to my issue.
