Notice Stream Timed Out Problems
    Hi Ronald
    The answer to question 1 is yes, but not ideal.
    Question 2 is possibly(?), check your Marantz documentation.
    As suggested in my previous comment on your other post, option 3 is your best solution which is to wire your NODE 2i to your router. A powerline Ethernet kit may be your best option if running a cable is not possible.
    Option 4 is select Help, Send Support Request and we can help troubleshoot...
