Question On Playing Tracks In ITunes Through My Bluesound System
AnsweredFirst I hope I am asking this is the right forum section. Is there a way to play the tracks (or “songs” in the world of I-Tunes) in my I-Tunes through my Bluesound system? (Iuse a PC with windows 10). If yes how is it done? I should say that the tracks in my I-Tunes are all “wav” files and and another reason is all the tracks in my I-Tunes are my very best favorite music tracks and I usually play them in shuffle mode. if it is possible to play them though my Blue Sound system can it be done in shuffle mode? The other reason I am asking this is I currently have 3325 tracks in my I-Tunes and it would take a long time to try and make a playlist in the BS system with same tracks. if possible to play the collection in my I-Tunes it would make it a lot easier.
Thanks
Hi Gregory
iTunes in Windows 10 - not a problem!
Here ya go; https://support.bluos.net/hc/en-us/articles/360000186887
Comment actions -
Thanks Tony…Read the information in the below link. One other question…. I assume that once the steps are completed does the process actually download or transfer an actual copy of the I-Tunes library into the Bluesound’s Library?
If the answer is “yes” does it come up as a new playlist? If not, assume it is placed in the Library somewhere? If yes how does it appear?
If no to both questions I assume it will just play the list from the computer which means the PC has to be turned on? If yes can the list be played in "shuffle' mode? Sorry for all the questions just do not really understand the outcome or how it will all work with the Bluesound system.
thanks
confused in Ann Arbor
Thanks
Greg
