Mqa problem
4 comments
    Avatar
    Hi Briggitte
    Your files are fine. It's not software decoding, its a pairing issue with your SUB. Can you please select Help, Send Support Request from the player that the RT100 is connected to. We would like to see the log file please and will reach out to you that way.
    Thanks.
    Comment actions Permalink
  • Avatar
    Brigitte Behnert
    Thx for your answer. The sub is currently connected with the Pulse2i. The same problem exists when connecting it to the Pulse2i mini. I don't understand, what do you mean with "send support request from the player that the RT100 is connected to. How do I create a log file? Can you give me please an example how to manage?
    Thanks in advance
    Bye Brigitte
  • Avatar
    In the BluOS App, select Help, Send Support Request from the Navigation Drawer (left side drawer where you select your musical sources). Please fill in the online form and submit it. This will send our Support Crew a log file of your Player and we will be in touch.
  • Avatar
    Brigitte Behnert
    ok, I send the online form a few minutes ago.
