Node 2 & LG Magic Remote
    Avatar
    Not us... it's your LG remote...
    Consult your LG manual and in the TV settings you have to connect a sound bar. You can use a Phillips as they use similar parameters as we do. Once connected, you can program the IR codes into your NODE 2 quite easily.
    Comment actions Permalink
