Obi mesh
    Avatar
    Hi Robert
    We don't see why not either but yes networks can be tricky sometime. Try it and let us know if you have any problems at support@bluesound.com and out Home Networking specialists may be able to lend some advice.
    Comment actions Permalink
  • Avatar
    Robert Calderon
    So just to be sure, if this option doesn’t work for me, other models do have WiFi connection option, is this correct ?
  • Avatar
    Correct
    Only the VAULT (Classic/2/2i) is wired only due to the 2TBs of storage.
