Inconsistent behaviour between Library and Queue, leading to wrong songs played
    Mark T.
    Sr. Support Crew Member
    Hi Guillaume,
    Similar to the community post you referred to, please send us a support ticket to support@bluesound.com and a member of our support crew will reach out to you regarding your issue.
  • Guillaume
    Just posting here as nothing is more frustrating than to come across a post with your problem but without any information on resolution.
    So, after engaging with Bluesound Support, it turns out the issue is with the metadata of the files. If you've accumulated music over a long period of time (20+ years), chances are some of your tracks from the early internet days may have dirty or inconsistent metadata. Some of them may have some alphabetical characters (e.g. "abc") for the year metadata, some may have a genre with a value that isn't from the supported list for ID3v1 etc.
    Based on some odd engineering design decision, when opening those files in the BluOS player, the sorting used in the "Library" view versus in the autofilled "Play Queue" is not the same. And the problem is that the order of the "Play Queue" is used even if you use the "Library" view, which I assume most of us would use. So if you click on files 8, 56 or 453 in the "Library" view, the BluOS player will play files 8, 56, 453 from the "Play Queue", which won't be the same as those you've clicked on in the "Library" view.
    Unfortunately, as of November 2025, there is no way for the BluOS player and clients to handle this properly. Short of a proper software resolution & bug fix, the only real solution is to go through the metadata of all your files, trying to figure out what could be wrong and fixing (BluOS Support helpfully suggested mp3tag for this purpose). Assuming you have time to do so. Once you've fixed, you need to rebuild the index from scratch (which takes extra time) as the updated metadata of your files won't otherwise be re-processed. After spending a few hours doing it, I still had several dozen discrepancies and gave up. This is all the more disappointing since this issue and inconsistent sorting behaviour did not exist until a year or so ago, when newer version of BluOS software started being unable to handle tracks with inconsistent metadata.
    Other workarounds include creating & using playlists (but then you have to maintain those), or using the autofilled Play Queue when navigating and clicking on songs (but that is a poor user experience due to several controls missing such as play/pause, volume etc).
    Hopefully this one gets solved in a future update!
