Crackling sound from Node Icon via USB
    Hi Fredrik
    I believe I answered this question multiple times for you - but in reviewing our Community, I see you have deleted your thread where I answered this.. I have a copy of that answer though.
    Review your DAC documentation to ensure it does not need a driver and designed specifically for a PC.
    Here is my previous response;
    Thank you, Frederik
    From your third-party DAC's website;
    USB Audio Class 2 (up to 32-bit/384kHz)*
    *Driver Installation Required
    This output is designed for a PC and not proper audio component playback. Please continue to use COAX, TOSLink or the analogue output of the NODE ICONs dual ESS Sabre ES9039Q2M DACs.
    We consider the matter closed.
Post is closed for comments.
