Bluesound Node Icon output switching fixed volume issue
Answered-
Not sure why you are switching between COAX and USB, but check your Audio Settings. When using USB, it is always fixed. When you select COAX, you must select FIXED OUTPUT. Disconnect your USB DAC, select Settings, Diagnostics, Reboot. Once The ICON has rebooted, set your Audi Settings to FIXED OUTPUT and play some content through COAX. You can then reconnect your USB DAC. Just a reminder, when a USB DAC is connected, all other outputs are disabled.
If problems persists, please select Settings, Send Support Request so our Support Crew may review your log file and
I was just checking which inputs were best on my new DAC, to answer your question. And yes, the reboot worked. It’s just frustrating for fixed volume to not be applied when I switch to USB DAC. But thank you for your advice.
Great news
For sure. The Icon is a wonderful device btw
4 comments
