BluOS Voice Control for Alexa: Long delays
AnsweredI am using the Alexa skill BluOS Voice Control on an Echo5 to voice-control my Bluesound NODE 2i. It worked nicely for a couple of years (I am mostly using the commands "tell bluevoice pause/play").
Since a few weeks the skill is heavily delayed: Alexa acknowledges the command immediately, but the execution of the command on the NODE 2i is done 1-5 minutes (!) later.
I already restarted and reconnected the involved skills and devices, but this didn't help. In general, I suppose the NODE 2i and Alexa are communicating via some servers at Amazon and/or Bluesound.
How could this be fixed or at least debugged? Are there any server logs one could check?
Hi Klaus,
Please reach out to our support crew by sending us an email at support@bluesound.com or by submitting a support request directly through the BluOS app.In the BluOS app, simply go to Help > Send Support Request and a member of our support crew will be happy to assist you further.
Thanks, will do so.
