Blue sound node icon
5 comments
    Hi Craig
    Though DIRAC Live will support external DACs connected via COAX or Optical, USB Output is not supported by DIRAC.
  • craig rendle
    Thanks Tony. Can you tell me if the signal will be degraded using the coax out instead of USB out to my ddc? I’m under the understanding that the USB out gives a much cleaner signal path
    In honesty, the more devices you connect in your audio chain the more the signal is altered. It is really for your ears to decide but we here at Bluesound trust the SnR ratio in the ESS Sabre DAC of your NODE ICON to create a neutral unaltered sound. We have implemented DIRAC to allow you to alter that to your taste.
    The cleanest signal path is the one with the least amount of devices - but again let your ears be the decision maker.
  • craig rendle
    Hi I have now connected a coaxial digital cable from the icon coax out to the s/psif- 2 connection on my dac and it is not finding the dac in the blue os app in output mode whereas via usb it was fining it fine. Any ideas?
    There is no configuration required... simply press play.
