Bluesound Node connection[?] Issue
4 comments
    Permanently deleted user
    Another long term user here, Bluesound does not need an Internet connection but it does need a stable network otherwise you can get symptoms like you are describing but equally it could be something else.
    I would start by powering off your Node and reboot your Router, wait five minutes and then power on the Node again. Give it five more mins and then try and see if you have issues.
    You could temporarily run an Ethernet lead back to your Router and see if the issue persists.
    When the issue does occur next, in the BluOS app please navigate to Settings and under Help & Support select “Send Support Request” this sends the logs to support who will then get in touch with you.
  • Flamur Abdiji
    Hi all! Unfortunately my node2i have started to behave the same.
    It has worked fine (like my other 2 devices) however now suddenly it looses connection I and have to reset it and start from the beginning. Yesterday I tried to restart my router as well while doing the factory reset and it connected immediately. This morning It has disconnected. This is also the node that is closest to the router. If anybody knows how I can proceed with this strange issue please reach out
  • Permanently deleted user
    If my post above does not help follow the instructions in the last paragraph.
  • JRB
    Found this thread because I'm having the exact same issue, seems to be related to recent updates. My internal library streams fine from my NAS, but any outside source constantly cuts out.
