N150 Powernode won't connect to my network
AnsweredMy Powernode is an N150. I bought it 10 years ago. Its been in storage for about 5 years. When I powered it up yesterday I just got a continuous red light. I waited. It didn't change. I phoned the Sevenoaks dealer that I got it from and he made a couple of suggestions (factory reset, ethernet cable) but nothing made any difference. Although its not been used for a long time it was stored safely and I'm pretty sure nothing is wrong with it - other than that the firmware or whatever is going be way out of date. If I can't connect to my router though I don't see how I can get it updated! Anybody got any suggestions?
Hi Peter,
There is definitely something else is going on with your Bluesound POWERNODE. I have escalated your feedback to a support request. A member of our support crew will reach out to you soon.
Thanks for #LivingHiFi
