Connecting external DAC to Node 130 via USB. No sound !!
    Permanently deleted user
    I downloaded the manual and searching the PDF could find no mention of using a streamer but does clearly state…
    “USB - By selecting this input, it is possible to connect CD 2.10 to a PC as a USB Audio Class 2.0 soundcard.”
    So, ignore the USB out on the NODE and continue to use the coaxial output.
  • Andrew Copley
    Thanks, I spoke to Canor, they stated it should be possible. I need to do a firmware update on the DAC apparently.
