Delete albums from Vault2i
8 comments
    Permanently deleted user
    Using a PC / Mac connect to the VAULTs share, delete the album and then run a rebuild index using the BluOS App.
  • Jim Soul Man
    The whole point of the Vault is that you shouldn’t need a PC connection to do things with it. That is a very disappointing answer! That really needs to get remedied!
  • Permanently deleted user
    I suggested a PC as that’s my preference but you can connect using an iPad using “Files” so it’s your choice of weapon really. I am glad Bluesound did not put a wipe vault or delete option in the App as someone in my house could easily delete my library if they have access using the BluOS App
  • Max Dekker
    That won't happen.
  • Jim Soul Man
    I sincerely hope that you’re wrong, but you’re probably right
  • Pinot Gris
    I do not have a Vault, so cannot speak from own experience. However, if it can be accessed from a PC, I would expect it to be accessible from a smartphone as well.
    I can access my music share from PC as well as smartphone, being able to add or delete music, or any other files. All that is needed on the phone is a file manager that supports SMB.
  • Jim Soul Man
    Thank you for the information. It still would be much better and easier off somewhere on the album options there was a delete album option.
  • Jim Soul Man
    One can do it for playlists, why not albums!
