Wifi hotspot player not found
AnsweredUnder settings in WiFi on iPhone, I am unable to find the player Pulse…
Is the Pulse in hotspot mode?
https://support1.bluesound.com/hc/en-us/articles/200271976-What-do-the-different-colors-of-the-LED-signifyYou could always temporarily connect an Ethernet lead from the Pulse directly to your Router, this will allow you to configure Wi-Fi settings, moving the Pulse if necessary to be closer if you don’t have a long enough Ethernet lead.
