BluOS 4.8.17 Firmware Issue: NAD M10 v3 no sound at all after update
4 comments
    Permanently deleted user
    Unfortunately this is the Bluesound community forum, you will need to email NAD support@nadelectronics.com
  • Charles Callaghan
    Hi Seppi,
    As I mentioned in the final paragraph of the comment, I already did and am waiting to hear back and it's been nearly two weeks.
    Is BluOS not maintained by Bluesound? Other users using the Bluesound Node devices are also experience sound issues with the 4.8.17 update.
    As requested, I would like to receive the previous firmware for BluOS from support. 4.8.15, I believe? This issue only started occuring for me (and others with Bluesound products) on the forum since that update. It is not available on the site to download and I would like to rollback as the previous version did not cause any issues at all.
  • Permanently deleted user
    I am just a Bluesound user, almost all posts regarding other manufacturers BluOS devices are asked to contact the corresponding manufacturer directly.
    -1
  • Charles Callaghan
    Right, and as I mentioned in the original post, I have done that already - in the meantime, since the device also runs on software developed by Bluesound, they can still provide the previous firmware (since it is their OS) and possibly assist by reviewing the diagnostic file I shared from the App to gain some insight.
    As stated, this is also affecting other users with Bluesound products since the firmware update, so it makes sense to check in here too.
Post is closed for comments.
