Network share problem
5 comments
    Permanently deleted user
    Try rebooting the NANO, in the BluOS App please select Settings, Diagnostics, Reboot to restart.
  • Pinot Gris
    If I recall correctly, a reboot may not be sufficient to get rid of the "ghost" share. This bug has been around for years.
    It occurs when you remove a share, while the BluOS device cannot access that share. E.g. because it is offline or the password has been changed.
    While it has disappeared from the Music library - Network shares configuration page, you can still see the remnants of the share on the Diagnostics page.
    -1
  • Alain DW
    Lossless
    I never had to try this but a workaround could be to first delete the share(s) in the BluOS app, before removing / changing the physical share. This in order to prevent the bug from happening.
  • Luigi Formisano
    Thanks guys, reboot worked!
  • Pinot Gris
    @Alain
    This is exactly what I have been doing over the last years, it never showed its ugly head again.
    What truly strikes me, is that BluOS does not bother fixing this. Thousands of users must have wasted their time on this bug, but apparently that is no issue to BluOS / NAD / Bluesound.
