Store/restore issues when using multiple USB SSDs
    Permanently deleted user
    The initial backup is a full copy, however subsequently they are incremental which is why if you add just a few CDs the backup is much quicker. So unfortunately swapping drives around is not going to work.
    I make additional copies using a Mac across my network, one copy onto the Mac’s external drive array and the other onto a NAS. The physical drive then goes off site, to be retrieved as and when required.
    Having a copy on my NAS means that all my CD / downloaded music is still available even if the VAULT is offline.
  • Kurt Guttenberg
    Hi -- Thanks for the reply. I guess if both the existing Vault and the home backup SSD were rendered useless due to some incident, I would need a new replacement Vault and that would likely recognize the 'off-site' drive as a valid backup. Not sure how to test that though. I'll have to check if the factory reset on the Vault erases the database. If not, I assume I could test the Vault that way with the remote SSD -- at least to see if the Vault immediately rejects or accepts the drive.
  • Permanently deleted user
    A factory reset of the VAULT does not erase the drive.
