Node N130 - Wifi Issues
4 comments
    Hi Rasmus
    Doubtful the Wi-Fi card is going - more likely a firmware update of the AP may have changed something. Please select Settings, Send Support Request so our Support Crew may review the log file and take a closer look.
  • Rasmus
    I did another reboot of the Node and right after it is ready again,  then the dBm values are normal (-52 dBm for both 2.4 og 5 Ghz). After a little while the signal drops to -64 dBm and stay there, the 5 Ghz network disappears at some point, but comes back and stays after about 30 minutes??
    No issues with other units, WiFi connections are rock solid.
  • Permanently deleted user
    I would try either Chanel 1 or 11 and not let Unifi do any of its automatic stuff and see what the signal strength is like in different channels.
    I don’t know your home but if you have neighbours they could have made changes to their Wi-Fi network and it’s interfering with yours, particularly at the location of the NODE.
  • Rasmus
    Thank you for the suggestion, but I have tried 2 different brand of AP's in both end of the house on all center channels, it never gets any better.
    The unit is 4 years old, maybe the wifi card is getting bad, or an error in the OS image driver.
