Node ICON weak bass/poor sound quality
AnsweredI’ve had my Node ICON for about 2 weeks now. It’s been great up until a day ago. For some reason, the bass suddenly seems weak and thin. Haven’t changed a single setting. I swapped out the ICON for my previous gen Node and the bass returned to is normal full level. I fear something in my ICON has failed or is starting to fail. I know the ICON is a new product, but have any new ICON owners experienced something similar? Any idea what could be happening?
12/24 UPDATE: I did a factory reset on the ICON and everything appears to be back to normal. Very odd. Any ideas what could have happened? To my knowledge, the ICON only did a software update when I first got it and turned it on.
12/26 UPDATE: everything sounds muddy with weak bass again. Not sure what is happening. Perhaps my ICON is defective?
Sorry to hear this Dave
Please select Settings, Send Support Request in the BluOS App so our Support Crew can receive a copy of the player logfile and help troubleshoot further.
Mine started out with much less bass than my old Node 2i. Subwoofer out is off. Exactly the same hardware.
Hi Dave, has the problem with the poor sound been solved? Unfortunately I have the same issue with my recente new bought Nide Icon. There is almost no bass, and it sound 'thin' and 'poor'. I don't understatement when I read all the positive reviews. I think it could do much beter?
Bluesound sent me a new unit and the problem was resolved.
4 comments
