Blusound Node audio keeps cutting out
    Permanently deleted user
    Hi Andy, do try a Router reboot followed by a reboot of the NODE once the Router is fully up and running, beyond that you may have a Router configuration issue that needs Bluesound to help you with.
    If you continue to have issues then the BluOS App please select Settings, Send Support Request, so the Bluesound Support Crew can review the log file and take a closer look.
    Edit you don’t say which output you are using but do try other outputs from the NODE bypassing a DAC if you use one.
  • Andy T
    I have tried all that. I have 2 more nodes at another house using the same routers and those work fine.
  • Permanently deleted user
    Sorry you made no mention of what you had tried so had to second guess.
