When to Rebuild vs. Re-Index
8 comments
    Permanently deleted user
    I tend to reindex when adding new albums but any deleting or changes such as metadata / artwork I run a rebuild index. My library (metadata wise) and ripping process is in great shape so hardly ever need to run the rebuild.
  • Pinot Gris
    Never use m3u playlists, but I make changes to my library regularly, several times per month. Always perform reindex as this is way faster and in most cases works fine. Only when I see oddities after a reindex, I will consider a rebuild. But only after first clearing the cache of the app I am using, as the cache can prevent properly showing the results of the reindex.
  • Joris
    It would be nice if adding and changing m3u playlists would be picked up by reindexing. I don't use them now just because they need a complete rebuild. I guess the original question asks why this is so, and this has not been answered.
  • Julian Redding
    Thanks for coming back. Thanks Joris, exactly. I add and remove tracks to my M3U playlists and find I have to rebuild every time rather than re-index. As you say, don't understand why this is so? Maybe Bluesound can clarify?
  • Alain DW
    Lossless
    I use .m3u extensively (windows app) and never noticed discrepancies after a reindex to update.
    Only to remove .m3u a full rebuild index is needed.
  • Julian Redding
    Thanks Alain. Agreed. Not technically sure of the difference but surprised when removing M3U's a rebuild is required which takes a long time. Surely, adding, removing and amending M3U's should be taken care of by a reindex?
  • Joris
    Still no reaction from Bluesound I see.
  • Permanently deleted user
    Bluesound marked my post as the Official Comment, if you want a personal response it’s always best to log a support ticket. Bluesound do read all the posts on this community forum but don’t always comment.
