Difference of quality
AnsweredFollowed by 2 people
Hi, is there a difference of quality of sound with using different outputs to connect a amplifier with dac :
1. Optical
2. Coaxial
3. Cinch
Is there a different use of Dac
Thank you for your answer.
Julius
Hi Julius
That is for your ears to decide. Try connecting your NODE via RCA analog to the amplifier, then try the different connections of the NODE to your third party DAC. Select and play the same content through the various options and go with what your think sounds best to you.
