Library on NAS drive not visible to one of my nodes
Followed by 2 people
    Brian
    Lossless
    Another Bluesound user here.
    I suggest you try removing then re-entering the share on the problematic Node. If that fails a reset might be called for.
    Failing that contact Bluesound support here: support@bluesound.com
  • Andrew Dixon
    Thanks I'll give that a try soon!
  • Andrew Dixon
    I tried removing the network share and re-adding it, nothing changed.
    So I did another reindex, it processed about 4,000 of my approx 26,000 songs and said indexing complete. No sign of my library, so I did a factory reset, added the share again and did another re-index and it is the same, indexed approx 4,000 out of 26,000 songs and said it was complete but still no library showing and diagnostics shows "Total songs: 0"
    I have no idea what to try next! It's late now so I'll raise a support request in the morning......
