Pulse M looses wifi connection
    Permanently deleted user
    You need Bluesound support to look at the logs, immediately after the player stop in In the BluOS App please select Settings, Send Support Request, so the Bluesound Support Crew can review the log file and take a closer look. If you cannot do this then use email support@bluesound.com
