Node Icon and NAD power amplifier
    Kristofer Hadodo
    Lossless
    They both work, unbalanced or balanced, the choice is yours. Depends on what sound you are after, your budget, your speakers, and your room.
    Best, KriHad
  • Brian
    Lossless
    I agree with KriHad though I will add that the build quality of the NAD Master series is better. Both are terrific amps and sound amazing.
    2
