Node N132 audio outputs
AnsweredI understand that all audio outputs on the node both digital and analogue are always on and hot, but are the signals in sync with each other? For example if I wanted to run a digital connection into one amp and an analogue connection into another will I be able to play both amps simultaneously?
Duplicate post, answered here:
https://support1.bluesound.com/hc/en-us/community/posts/4410229496343/comments/26931506323351
