Subwoofer crossover setting missing
    With your Home Theatre Group selected as the current Player, select Settings from the Home Page. Select Audio Settings. Open the Subwoofer settings by tapping the word SUBWOOFER. You should see the availability to adjust the crossover form 40 to 200 Hz.
  • John Corbett
    Hi, I have exactly the same issue. The crossover setting is unavailable when the subwoofer is in a home theatre group. Any ideas?
    Thanks
    John
  • Simon
    Same problem, when following the above instructions there simply isn't any option for crossover.
