Valut 2. solid red after upgrade
AnsweredHi I have solid red light (play bottom)
it came after i did make latest upgrade
I did try to factory reset it but no luck there.
it still RED
It´s wired LAN cabel and BluOS can´t find it anymore.
In the BluOS App please select Settings, Send Support Request, so the Bluesound Support Crew can review the log file and take a closer look. If you cannot do this then use email support@bluesound.com
Hi. app it is locked. se picture
I quote from my own post
