Connecting an AudioEngine speaker to a Vault 2i
4 comments
  • Cliff McKnight
    Not sure I understand, sorry! My phone is connected via wifi to our router (which is BT) and the Vault is connected to the router via an extender (ethernet from Vault to mains, mains to router ethernet port) so everything should be on the same wifi network. I tried moving the AudioEngine into the same room but that didn't work. I suspect there's something here I'm not understanding :-(  there usually is!
  • Cliff McKnight
    Thanks for your patience. I've made sure the AE speakers are showing as disconnected under Bluetooth on the phone. I've then followed the document to connect as headphones. Under 'Devices' it shows my two Flex speakers and something "0022:d9:1bc7" and the search status is cycling perpetually. If I click the context menu for that device the options are 'disconnect' and 'forget'. Seems to be getting closer ...
  • Cliff McKnight
    OK, will do. Will let you know if I'm successful, thanks for your time and patience. Best wishes.
  • Cliff McKnight
    Hello Seppi,
    It works! Turned them both off for 5 minutes, moved them closer together, went via the 'connect headphones' route, the AE showed up and could then play to it. It still works when I moved it back to the other room.
    Again, thanks for your time and patience.
    Best wishes.
