Outside connection
AnsweredIs there a way to connect the app to my home music while outside home ?
As is no, and beyond the scope of this community forum.
However It’s possible depending on your level of technical ability. Suggest looking at setting up a VPN on your Router or even using software to take control of another machine using something like TeamViewer.
