Playback problem with Tidal HR files
Followed by 2 people
    Hi Eduard
    Connect the NODE using RCA cables to your amplifier to rule out a playback problem with the NODE. If the NODE plays fine this way, double-check your external DAC documentation to confirm it is not locked to a certain output only or does support 24/192 playback.
    If the NODE is not playing 24/192 playback out of the RCA connectors, please select Settings, Send Support Request in the App and our Support Crew will help troubleshoot further but I suspect it has to do with 24/192 playback on the external DAC.
  • Eduard
    Dear Tony
    Thank you very much for your quick reply.
    Your right that the HR files are playing on the RCA line-out on the Bluesound node.
    It’s strange however that some HR-files are played trough the coaxial connection to my external DAC and others aren’t.
    In the past, when MQA was still active, my DAC showed regularly files up to 24/192kHz. So as far as I can see there is no lock on my Mytec DAC who even threats HR up to 24/384kHz and DSD256.
    Best regards,
    Eduard .
