RT100 with Pulse Mini 2is (fixed) and Fenton Subwoofer
Answered-
This is no longer possible as the Bluesound RT100 was discontinued in 2019 and is no longer available. You would have required 2 of them for your purposes.
If you want to connect a SUB to your PULSE MINI 2i, you would have to use the Bluesound SUB+. That being said, not sure your selected active subwoofer would be a good match for your MINI as this would be better designed to work with a component product such as the NODE or POWERNODE.
Thank you for your response Tony, I have a way of acquiring two RT100s on the Internet despite them being discontinued. The subwoofer of choice is just the best for a low price. Do you know what cables I will require for this? I gather the RCA that comes with the RT100 may fit the subwoofer, but the cable for the RT100 to the actual speaker is the bit I'm confused about as there are 2 ends to the one end of the RCA, but one to the mini 2i? I also see the same connection options on my node 2. Do you know what cable is required?
Thanks,
Alana
