Node 2i does not recognize 32 bit 192 kHz WAV files
AnsweredHello-
I have moved from 24 bit 384 kHz FLAC files to 32 bit 192 kHz WAV files in an effort to get as close as possible to 'live' playing my vinyl collection.
All of my 24 bit files play fine on the Node 2i, however, my 32 bit WAV files do not even show up on my library.
I have re-indexed several times to no avail. I even went to Diagnostics and rebuilt the index several time also to no avail.
I need some help in fixing this or the 2i will find a new home.
Hi Steve,
It seems like you may have had a chat with our support crew yesterday. If that wasn't you, could you please get in touch with our support crew by submitting a support request through the BluOS app?
By doing this, the app will automatically send a log file to our support team, allowing them to better understand and address any issues with your Bluesound product.
Thanks for #LivingHiFi -
It was me yesterday.
Also, I just tried putting the 32 bit WAV (album) files on a USB stick and none of the songs show up on the BlueSound controller either.
Frustrating as your info says it will play 32 bit sound at an upper 192 kHz sample rate.
Seppi-
That was not my understanding from the marketing. Nutz.
Now I have a Node 2i for sale.
Hi guysI have spent the last five hours to get this to work. I have the Node N130. My latest progress is that now I have succeeded to get it to stream 32 bit / 48khz:-). Anything higher than that only makes a spinning circle around the play-button in the app.
My Michi X5 Series 2 is capable of 32/384 so I wont give up but it seems that the limitaion is on the Node unfortunately
Best regards from Sweden //Fredrik
4 comments
