BluOS Controller 4.4.0 not compatible with MacOS 15 ?
AnsweredHello,
I'm testing the new MacOS 15 (Version 15.0 Beta), but I cannot download the latest BluOS Controller App Version 4.4.0 via App Store: I get the message "Not compatible with this device".
But downloading the .dmg file via Windows it was possible to install und run the BluOS Controller App 4.4.0 on MacOS 15.
Br, Hubertus
You could try the direct downloads from the Bluesound Website, please note that MacOS 15 is not tested for compatibility until such time it’s publicly released.
https://www.bluesound.com/downloads/
Edit.. I see your post edit and you managed to download.
Hi Seppi,
yes, that's what I did and the app is running ...
Br, Hubertus
