node2 firmware upgrade fail and doesn't work
Answeredhello,
I use node2
Recently I try to upgrade new firmware.
But node2 isn't working in upgrade process and solid red light.
I turn off and turn on and then node2 isn't working
My BluOS Controller shot is here
Pls help me to fix my node2
Thanks
Hello there,
I've escalated your feedback to a support request. A member of our support crew will be reaching out to you shortly.
Thanks for #LivingHiFi -
Thank you for your feedback
I will check it tonight
I want to ask one thing.
After firmware upgrade fail I do factory reset.
And turn-on node2, light is solid blue and same screen of BluOS controller.
Is it possible informed way?
Probably a communication issue betweem Node and router, after the factory reset & update.
Reboot your router: cut power to Node and router, wait 5 min., restart router, wait 5 min., restart Node.
