Nad 368 mdc ethernet port speed
AnsweredIs the ethernet port on the NAD 368 with BluOS a gigabit or 100 mbps connection?
Hi Bruce
The BluOS 2i MDC is Gigabit Ethernet. The original BluOS MDC may only be 100BaseT. the 2i was released in 2018. The easy way to check is if your BluOS MDC supports AirPlay, you are Gigabit.
If you are unsure (as maybe an Android User), e-mail a picture of the back panel to our Support Crew at support@bluos.net and they can help.
