Node design flaw-easy fix
I've had 2 nodes, 2i, Gen 3 and there is one flaw and that is the recessed connections, coaxial, rca, sub. Could you please design that to where the connections are flush with the body of the node. I've had more coaxial digital cables that I couldn't fit into that small opening. Not good. Great streamer though.
0 comments
