Switch Network to Wired/Ethernet Connection?
5 comments
  • Andrew Lloyd
    Rebooted all network points -- router, switch, node, amp -- so far no choppiness, but still would be interested if there is a way to set wired/ethernet to the default. Still not seeing that -- only WiFi options with no ethernet option.
  • Alain DW
    Lossless
    There are no settings needed. Once a networkcable is inserted the Bluesound devices automatically switch to the ethernet connection. You will see the blinking led lights on the back when connected. The blue led on font remains blue to indicate router connection.
  • Andrew Lloyd
    Thank you Seppi -- I see what you mean about the diagnostics; that seems to indicate the Node and Amp are connected via ethernet now, great. No more choppiness so far. For what it's worth, the green LED light in back flashes on the Amp, but not on the Node for some reason.
    Anyway, thanks!
  • Lee Knoll
    If anyone wants to see their connections, login to your router. It will show those devices that are wired and those devices that are wireless.
  • Jan D
    „Hi, I have a Node 2i and would like to order a second Ethernet cable identical to the one included in the box. Can you tell me the exact model or specifications (AWG, shielding, brand) so I can buy an identical one?”
