Powernode Edge : do adjustments in subwoofer crossover frequency affect main speakers?
AnsweredI know here is a post answering this similar question regarding the regular Powernode, but i havent found an answer whether the same applies to the Powernode Edge:
Powernode Edge :
Will the subwoofer cutoff freq. set in settings affect output freq. to the main speakers as well? Say if sub freq cutoff set to 80Hz, will the main speakers also be cut off BELOW this, or will they be unffected by the setting and receive full range?
Same for POWERNODE and POWERNODE EDGE, can be toggled in the settings.
Thanks, Seppi
